If I am correct, the Disco I comes with a 3.54 rear end. What other gear ratios can be fitted? I would like to fit a higher ratio - probably something around a 2.73 or so. Is that possible? If so, where can such gear sets be obtained?
Why would you want to do that? I do not think it would move with that high of a ratio...3.54 is actually quite tall as it is. most Jeeps have 3.55 0r my 98 had 3.73 and the 4 cylinders all had 4.11 as well as the Rubicons...Most people look for lower gears not taller ones. I doubt taller gears even exist actually.
2003 Disco SE7 expedition prepped
1998 Disco LSE 7 50th anniversary Baluga Black
1996 Disco XD Trek number 4 and Camel Selections
1969 Series 2A 109
Not to mention 2.73 is a lower ratio, not higher.
It is higher gearing however.
In any case, here are some alternative ratios that are available:
http://www.ashcroft-transmissions.co...ewCat&catId=12
Tom Rowe
Four wheel drive allows you to get stuck
in places even more inaccessible.
62 88 reg
67 NADA x2
74 Air Portable - The Antichrist (tag 6A666)
95 D1 - R380
95 D90 - R380
97 D1 - ZF
Basically, that's it. Apparently, there are a few, relatively rare, LT230 tc's with 1:1 high range gearing. My goal is to wind up with 2000 rpm = 70 mph using the highest gears. Virtually impossible without an overdrive somewhere in the system.
Yeah-It doesn't help that the LT230 more or less cancels out the OD ratio of any transmission hooked to it.
Go talk to Ashcroft. Don't forget taller tires can be part of the gearing equation.
I am looking at doing the same thing. If I can get a 3.08 set in both axles that would put my disco II at 2108 at 70mph. Anybody know if this would be something that would hard break the drive train for make it not driveable?
