Originally Posted by
BackInA88
To replace the synchro assembly you have to remove the trans.
technically this is not true. you could slide the trans back a few inches and pull the bellhousing and top cover. might save a little time over pulling the seatbox and breaking the transfer box from the gearbox etc. While you are in there you can replace most of the bearings too, and the clutch. (Ask me how I know this) Minor point but just for the record if this is the only problem you have you could save quite a bit of disassembly by NOT pulling the entire gearbox out of the car.
