Results 1 to 7 of 7
Thread: Starter stays engaged.
    Default Starter stays engaged.
    I had the starter swapped and rebuilt and it stays engaged but when I turn it off it stops. I'm thinking it's in the key switch and not the starter. I think I might put in a push button and eliminate the key crank. Any Thoughts???
    46 cj2a
    69 bronco
    72 bronco
    74 bronco
    76 wagoner
    79 bronco
    95 disco
    03 focus svt
    May 2006
    2,020
    Sounds like a bad ignition switch, probably a worn electrical part. Is it manual or auto?
    # RNH583 Switch and harness. In stock.
    Quote Originally Posted by Les Parker View Post
    its a 5 speed, so it sounds like the ignitions switch eh? are they difficult to swap out?
    46 cj2a
    69 bronco
    72 bronco
    74 bronco
    76 wagoner
    79 bronco
    95 disco
    03 focus svt
    Oct 2011
    Mountains of Western Pennsy.
    592
    Not too difficult to change out, pretty pricey part though. Hardest part is removing the clamping bolts, I had to use a sharp punch to coax mine out, after that just unplug the old, plug in the new, and rebolt it in place with new bolts. (They use pretty strange bolts for this, I don't know why...) Look for a 'RAVE' disc with the shop manuals on it, if you don't have a manual, it's a free download on the net.
    '95 R.R.C. Lwb
    '76 Series III Hybrid 109
    '70 Rover 3500S
    Quote Originally Posted by mearstrae View Post
    '95 R.R.C. Lwb
    '70 Rover 3500S
    Do ya think I should just put a starter push button in and be done with it??
    46 cj2a
    69 bronco
    72 bronco
    74 bronco
    76 wagoner
    79 bronco
    95 disco
    03 focus svt
    Oct 2011
    592
    May be a cheaper way to go. I don't know if the small switch at the end of the complete ignition set-up is available by itself, it's probably all you'd need. On mine the key got jambed and I had to change the works, same symtoms; engage starter and it keeps cranking, the key mechanism wouldn't let the switch return to normal run.
    All you'll need to do if you put on an external start button is deactivate the start wire at the steering column switch and run fresh wires.
    '95 R.R.C. Lwb
    '70 Rover 3500S
    '95 R.R.C. Lwb
    '70 Rover 3500S
    ok thanks, going to order up a starter switch this week.
    46 cj2a
    69 bronco
    72 bronco
    74 bronco
    76 wagoner
    79 bronco
    95 disco
    03 focus svt
