Results 1 to 10 of 10
Thread: oil recommendations
    Jul 2010
    Boyle Heights, Ca. (L.A.)
    108
    Default oil recommendations
    greeting fellow rover enthusisist! i just recently purchased a defender 110 with a 2.5 diesel n/a..... does anyone know what kind of motor oil it takes??? what about the tranny and diffs?
    thanks you very much!
    May 2006
    2,020
    In the LT 77 or R 380 Gearbox use MTF, axles/Transfer box : 75/90w Hypoid oil, engine/filter 15-40 (we use Amsoil on all of these )
    Jul 2010
    108
    Les.... Thank you! Also.... WHat is "MTF"?
    Jan 2010
    1 hour North of Rovers North
    144
    Quote Originally Posted by l.a. rover View Post
    Dexron. Automatic Transmission Fluid.
    67 angry hamsters
    MTF=Manual Transmission Fluid.
    It's not the same as Dexron ATF.
    I use Redline MTL in the gearbox.
    For motor oil I used Drydene Dieseall for many years, now owned by Castrol.
    Shell Rotella T would be good.
    Tom Rowe
    62 88 reg
    67 NADA x2
    95 D1 - R380
    95 D90 - R380
    97 D1 - ZF
    Jul 2010
    108
    thanks tom! I guess i didn't understand MTF cause my mind was thinking series rovers... hence 80-90w gear oil....
    Quote Originally Posted by antichrist View Post
    Jul 2010
    108
    one more thng .... does anyone know what the oil capacity of the 2.5 na diesel????
  8. #8
    Jan 2010
    144
    5 litres is just about perfect on mine.
    67 angry hamsters
  9. #9
    The manual states 7.23 US quarts with a filter change.
    It will vary by about a pint depending on if you're using long or short filter.
    Tom Rowe
    62 88 reg
    67 NADA x2
    95 D1 - R380
    95 D90 - R380
    97 D1 - ZF
  10. #10
    Jul 2010
    108
    thanks.... cause 5 qts wasn't cutting it !
