Results 1 to 2 of 2
Thread: 1313 and 1314 error codes ?fix?
    Jun 2007
    CA
    3
    Default 1313 and 1314 error codes ?fix?
    How does the ECU detect the missfire and how can it be fixed? I had a bad alternator with a bad diode. Fixed that and this is the last code.
    Could it be the O2 sensors or the Cats?
    Jun 2007
    CA
    3
    Default Fixed
    FYI
    Found the problem. A few of the crank speed tabs on the fly wheel were bent. They were hit by a bolt left in the bell housing. What a needle in a hay stack!
