Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 34
Thread: runs like crap
  1. #21
    Jun 2008
    Southern California
    86
    Unfortunately, it's not the valves -- I adjusted the valves today and it's still exhibiting all of the bad symptoms. I'll do a compression check soon.
    Next up is the fuel pump and lines, I suppose. It just seems like uneven fuel to me...
    Any other thoughts?
  2. #22
    Dec 2011
    176
    OK, one thing before I did the valves was to seal every possible vacuum leak spot. I took both manifolds off and dismantled everything between the head and the brake booster, including my Rochester. Every joint got sealer, new gaskets (or both), new hoses & clamps. It didn't solve every problem, but it sure helped, and it eliminated vac leaks from the equation. That's what narrowed my issues down to the valves. Eliminate as many problem areas as you can.
  3. #23
    Nov 2012
    Edmonton AB
    202
    Quote Originally Posted by andrew View Post
    Any other thoughts?
    Throw a fuel pump at it, if that's not it then you'll have a spare for trouble shooting next time. Make sure the lines are tight on the pump.
  4. #24
    May 2006
    2,020
    I would second the thought of a new fuel pump. Ethanol plays havoc with fuel pump diaphragms.
    Les Parker
    Rovers North Inc.
  5. #25
    Apr 2013
    Park City UT
    167
    Speaking of fuel pumps, I've found an in-line low pressure electric fuel pump in-between the standard fuel pump and the Carb with an on-off switch inside the cab helps prime and fill the float bowels in the carb for easy starting and can serve as the pump if the diaphragm fails on the mechanical pump. Also use one of the many ethanol conditioning products out there to treat your gas and prevent ethanol damage to various parts of our Landy's. This goes for any older car as the rubber used on them does not hold up well to ethanol.
    Motor On,
    Bugeye88
  6. #26
    Jun 2008
    Southern California
    86
    I hate threads that I look up that have no closure, so here it is:
    My next steps were to check the compression (great, by the way -- 170 plus or minus 5 across the board) and add a new fuel pump. I also blew out all the gas lines with compressed air while I was at it. No change really. Unrelatedly, I added a new water pump (had been developing a slow leak for some time), hoses, thermostat, belt, and heater control valve (broke upon removal of the hose).
    None of this really helped or mattered very much. So, at this point I've replaced nearly everything that might have reasonably caused the problem. A lot of it I was going to replace anyway as maintenance (points, plugs, condenser, plug wires, water pump, belt; and valve adjust) so that was no big deal, but some was a shot at a fix that I apparently didn't need (fuel pump, etc.).
    So...I said screw the specs I'm timing this thing by ear. Recall that I was at or around TDC (8:1 head)...I rotated until it sounded strong. Drove it for awhile. If it backfired I backed it off. If it was good I moved it more to see if it got worse or better. I always drove between adjustments until it was warm. After a bit of trial and error I settled in on a happy place. The truck sounds wonderful now and runs great again. I haven't pulled out the ignition light to see what the final number is but I'm guessing I'm at about 8-12 degrees BTDC, which seems way out of wack from where it's "supposed" to be. Oh well, screw it, it's quite happy.
    I'll drive it, keep an eye on the temperature (see if it continues to run cool, so far so good) and the points (see if it burns through them), but I think it's resolved. It truly is running great (and so quiet with the new water pump and valve adjust!).
    I guess the only question I have is whether it's possible that the crankshaft pulley was installed with the mark in the wrong place, or if it could have slipped/moved over time... I just can't imagine how else I could be running so well so far off the supposedly "correct" timing.
    Happy driving.
  7. #27
    Jul 2008
    Stafford CT
    238
    Sounds like you found your fix! I know every time I try using the timing light it never works and I always resort to my ear.
  8. #28
    Apr 2007
    Scottsdale, Arizona
    889
    I am running at about 12 BTDC and that is where my engine is happiest. With ethanol in the fuel, you can't go by the book specs.
  9. #29
    Apr 2012
    Bergen County NJ
    265
    On my the engine, the crank pulley has one tick mark and then the pointer has two points which basically get you around 0 degrees. So when you actually time it to run right, the markings really don't help because there are none out by where it's happy! (Unless I'm doin' it wrong) Time, check for detonation, tune, check, tune, check etc... you got it.
    glad you figured it out..
    ~Steve
    ---- 1969 Bugeye ----
    ---- 1962 Dormobile ----
  10. #30
    Apr 2007
    Scottsdale, Arizona
    889
    I have a few timing marks on my crank pulley, but like Steve, there are no marks out that far. That's why I said about" 12 degrees BTDC.
