I put a speedi sleeve on my 2.25 front crank pulley and it leaks worse. Sleeve is in the correct place and the correct diameter. I didn't use anything to seal it but thought it was tight enough to seal by itself. Any tips would be appreciated.
Assuming that you also installed a new front crank seal, speedi sleeves may not cure a leak if the oil can sneak under it. Best bet is to find a new pulley.
I've never had luck on the crank pulley, even with sealants. New seal and pulley was the best solution for me.
Jason
Well if you're industrious enough like me, you simply take your used 90 wt or motor oil(or a blend to be authentic), put it in a garden sprayer and use it to mimick the leaks as if you were doing 50 mph on the interstate. Kill two birds with one stone because then it drips all over you driveway like it would in nature. (Except you probably can't tell by now with your driveway).
Jason
Yeah, you should use sealant under the sleeve and wiped off the excess. I like the black oil resistant hi-temp stuff myself.
anyone have the correct skf speedi sleeve part number for the 2.25 ?
1964 Series IIa In progress
1968 S IIa (Sold)
1972 S III (Sold)
1996 Discovery SE-7 (Sold)
Clean the pulley & the sleeve with brake clean, add Loctite, press on sleeve...DONE !.........donnie
I spent most of my money on women & cars, the rest of it I just wasted.......
