Results 1 to 7 of 7
Thread: safari top question
    Jul 2010
    29
    Default safari top question
    I rescued a 109 recently, the safari top (pic attached) has sills over the top of the oval windows, none of my other 109's have this.
    Is the sill something Land Rover had on certain models, or later versions? or is it something a previous owner had installed?
    Any help / insight would be most appreciated.
    Regards,
    David
    Feb 2008
    East Quogue NY
    327
    I have those sills/gutters on my '63 88" station wagon. They are original equipment; on a regular top they might be helpful, they're sort of vestigial under my sun sheet.
    Apr 2008
    The Granite State (NH)
    3,435
    My '73 109's tropical top didn't have those gutters above the alpine windows. Perhaps it was an early variant?
    --Mark
    Mass.
    1,796
    My '65 top has them so perhaps you're right and they did away with them later on.
    Jason
    Apr 2008
    3,435
    Perhaps in true rover fashion, Rover expected the alpine windows to leak so they added the gutter to divert the rainwater. Oddly, this is the only part of my rover that DIDN'T leak on mine, which probably explains the absence of the gutters on later Rovers.
    Maybe they should have put some extra gutters above the doortops, along the "a" pillars, at the upper and lower windshield area, in the engine bay along the entire length of the bulkhead from top to bottom, around the transmission hump and around all the rubber shifter boots.
    --Mark
    Mass.
    1,796
    Every rover should come encased in one of those big plastic balls. Drive around and just drain the oil out of the ball once in a while.....
    Jason
    Jun 2009
    Columbus, Ohio, USA
    740
    +one
