OK, I'm being high maintenance about this thing. So I'm to the point where I have to pull the shaft from the intermediate gear. I've removed the little bolt and plate that hold it in, but all I have is a simple pitman arm puller. I'm not having luck using a lever and fulcrum to remove the shaft, so can someone tell me what sprocket puller I should get for this?
