Originally Posted by
I Leak Oil
Perhaps I'm just in a bad mood today but without any real info how does this answer his question?
Well.............if you looked at the specs for the speaker you would see that the speaker in question is 3 1/2 inches deep, which is too deep for the landrover door with a flush door card. Pretty simple EH! But not knowing what the door card the OP has is like as I've never seen one, it might protrude out into the cab 2 inches from the door which would of course be silly to reduce the interior size that much but who knows. I have installed more than my fair share of door speakers along the way and know that if the speaker touches the door interior it will rattle. Also it's not the back side of the speaker other than the voice coil to be concerned about in a landrover, it's the front side from hosing down the interior or rain at an angle. I have waterproofed the front side of speakers before using a water proofing spray, but if you are wading even a little the moisture will eventually get the cones and the voice coils, just be prepared to replace them occasionally.
