Results 1 to 10 of 10
Thread: Galvy bumper & "welding" issue
    Dec 2011
    Virginia
    172
    Default Galvy bumper & "welding" issue
    The PO of my Series 2a had welded a brush guard on the the front bumper. As it was rusted out and I didn't like the look I cut it off. Now I am grinding down the welds to the galvy bumper. Of course they will appear as rusted spots now...guaranteed...so has anyone done anything in the past to keep the galvy look (ie no paint) and deal with small spots of rusted welds???
    I know - if I am that worried - buy a new bumper...just wondering if anyone has a little "magic" they can share!!
    1963 Series IIa 109" 5 door Safari top (SOLD to new home)
    1971 Series IIa 88" Soft top (SOLD to new home)
    1995 RRC - LWB
    2001 Discovery II SE7 (SOLD to new home)
    dip it in molten zinc - they will go away
    Mass.
    1,796
    Quote Originally Posted by leafsprung View Post
    That only works if your bath tub is big enough...and not made of fiberglass.
    There really is no magic. Only thing you could try is to remove the rust and hit it with some cold galv. spray from a can. Have no illusions though, it will not look the same or match the surrounding galvanizing. Will not weather the same or as long either.
    Jason
    Dec 2011
    Virginia
    172
    thanks Jason - I didn't know you could get Galv spray?
    Has anyone applied this... http://www.homedepot.com/p/Rust-Oleu...3#.Ucwpv-tFwV4
    I am thinking that if I spray the whole bumper it will look best?
    1995 RRC - LWB
    Jun 2009
    Columbus, Ohio, USA
    740
    The cold galvanized spray will not last long on the galvanized portion of the bumper; it'll chip right off.
    You've got some galvanizers nearby to you. Consider taking it over and paying a few bucks to have it dipped! http://www.galvanizeit.org/galvanizer-locator/state/VA/
    Feb 2007
    Phippsburg, ME
    886
    Quote Originally Posted by 1971Series88 View Post
    I've used this many times with great success. Rustoleum also makes what they call "Bright Galvanizing" compound (same style can) that looks more like fresh hot dip than the gray stuff shown in the link.
    That said, Tony et al are correct that re-dipping is the ideal way to go. However, in cases where dipping isn't practical the galvanizing spray can work well. We use lots of salt up here, and I have parts on my truck sprayed with galvy spray that still show no rust after 20 years.
    If I were you I'd just spray the bare spots and see how it looks. Then give it some time to weather and see how it blends in.
    Just my $0.02......
    Ted
    Aug 2007
    Wenham, MA
    310
    I would do a little leg work on the galv paint that you use. They do not perform anywhwere near as well as a hot dip galvy coating does, and some are downright useless. This has to do with the percentage of zinc in them. The best cold galvy I have come across has to be the ZRC cold galvy paints. The one quart of ZRC paint I bought years ago weighed about 5-7lbs. due to its zinc content. Good stuff, the only downside to cold galvy paints is that they are more susceptible to road debris chipping away and removing the paint whereas hot dip adheses much better and is less prone to road rash.
    Feb 2007
    Phippsburg, ME
    886
    Quote Originally Posted by SalemRover View Post
    Absolutely true. The higher the zinc content the better (IIRC the Rustoleum in the link is 93%). The last galvy spray I bought was from a marine store, so it was formulated for salt water conditions (or at least that's what the can says). The "Bright Galvanizing" spray I referenced earlier has a lower zinc content (high 80's, I think), so if a part is going to show I use the marine grade spray and then use the bright stuff as a topcoat.
    In an ideal world I'd be like Tony Cordo and dip everything (Tony, have you dipped your upholstery yet??? ), but I don't have that option. The spray is, in my view, a reasonable alternative for some applications.
    Jun 2009
    Columbus, Ohio, USA
    740
    Quote Originally Posted by TedW View Post
    My new seats just arrived...
    http://www.antiquaireonline.com/wp-c...y-2009-040.jpg
    May 2006
    2,020
    Sweet, heated, lumbar supports, inbuilt ashtrays...................
    Les Parker
    Rovers North Inc.
