If you have no fuel to the carb you can work backwards to a fuel filter (assuming you have one). If it's clean and still no fuel to the carb, continue to work backwards to the fuel pump. Clean the glass bowl and re-seat in the rubber gasket..........if it does not seat perfect you are going to get an air leak and it's not going to prime. While it's a pain in the ass the best way to ensure a tight seal is to pull the pump off the block and re-seat the bowl on the workbench, then re-install the pump.
The little hand prime sucks.......keep turning the motor over with the key to get it to prime.
If you still get nothing you can go backwards yet again and check the fuel pickup tube and screen. If your tank is full of rust, dirt or water drain it.....clean it.....change the filter and try again.
There are only a few things that are going to screw you up between the tank and the carb:
- Pickup tube/Filter
- Fuel Pump
- Paper inline filter
Process of elimination, around six beers, philips head screw driver and 1/2" open ended wrench should cure what ails you.
