Umm....let's see...Might check:
Fan belt is still there
Radiator not clogged
Radiator fins not jammed up with junk
Nothing obstructing ram-air from getting to the radiator (no fuel cans/water cans/winch/rad muff)
Water pump pumping water
Thermostat installed and functioning properly
Ignition timing correct
Fuel mixture not too lean
Head gasket not blown
Engine oil present and in the correct quantity
Good oil pressure
Stuff like that...
--Mark
