The high setting works fine when I pull the switch to the second position but the low setting does not turn the fan on at all. Any help???
Mine's always been the same way. I think it might have a cracked board or a bad resistor.
'67 sIIa 88
The Kodiaks have a single speed blower motor.
High speed is full voltage going through the switch to the motor.
Low speed puts a resister in series with the motor which provides less voltage to the motor. The motor turns slower. You could have a bad connection in the switch or the resister could be bad. It is VERY common for these resisters to burn out.
Sorry I do not know the resistance and power rating of the low speed resister.
Teriann Wakeman_________
Flagstaff, AZ.
My Land Rover web site
Hello,
Can you please tell me where the resistor is located and if a new one can be purchased.
Todd
66 IIA 88"
93 Porsche 968 variocam 6spd
50 Ford 8N
Should be integral with the switch mechanism. I replaced mine with a two position pull heater switch from NAPA. Mounts in the same place and functions the same.
Jason
No. The replacement switch is a 2 speed generic pull switch meant to be used on blower motors. It is NOT a regular toggle switch.
Jason
If it helps, this is the one I used to replace my Mark 3 heater switch. To the best of my understanding it is the same as the original (though I can't comment on whether the same is true for the Mk4).
http://www.colehersee.com/home/item/cat/143/68028/
That's essentially the same as what I bought at NAPA.
Jason
The switch on my Mark III was missing the resistor so I used a pulse width modulator I picked up on Ebay. Now I have variable speed control. Much nicer in my opinion. I also picked up a new blower motor at Napa. They had it in stock!
1976 Honda CB750F1
1974 Honda CB360G
1967 Series IIA
