Results 1 to 8 of 8
Thread: Engine revs when press brake
    Apr 2010
    148
    Default Engine revs when press brake
    I noticed today that when I press the brake pedal in my 1970 IIA, the engine revs higher. As soon as I release the pedal, the engine slows again. I'm not sure if it's related, but recently I've also started to get a strange creaking sound when I press the brake. Any idea what could be going on?
    Thanks.
    1970 Series IIA
    1964 Series IIA [sold]
    Apr 2007
    Scottsdale, Arizona
    889
    You need to replace your vacuum booster.
    Apr 2010
    148
    OK, confession of ignorance. What's a vacuum booster?
    1970 Series IIA
    Jan 2008
    Portland, OR
    337
    It's the big black thing in this photo.
    '67 sIIa 88
    Apr 2010
    148
    Got it. Thanks.
    1970 Series IIA
    Apr 2012
    Bergen County NJ
    265
    (probably)
    your brake booster, servo, whatever you want to call it is what takes your engines vacuum and turns it into "power" brakes. It's the only thing that connects your brakes and engine and so logically it's causing the problem. Sounds like the diaphragm or something inside the servo has gone south so when you hit the brakes, you get a vacuum leak and weird revving.
    OR your boots are too wide and when you hit the brake pedal you are also hitting the gas pedal. haha
    ~Steve
    ---- 1969 Bugeye ----
    ---- 1962 Dormobile ----
    Jan 2013
    The South
    127
    Quote Originally Posted by Revtor View Post
    (probably)
    ~Steve
    Yep, I actually have the opposite problem but the only logical thing would be your servo. Mine actually kills the motor when the brakes depressed and I assume it's a faulty diaphragm.
    Anyway, swap that out and you should be good to go.
    1969 IIA - Tan
    1969 IIA - Blue
    Oct 2011
    Mountains of Western Pennsy.
    592
    Look the situation over carefully, it may be a bad vacuum hose or connection, not the booster (servo) itself. And a vacuum test gauge is a helpful thing in the toolbox, good for several things.
    '95 R.R.C. Lwb
    '76 Series III Hybrid 109
    '70 Rover 3500S
