Results 1 to 5 of 5
Thread: Thread size for sender unit.
    Northern NJ
    45
    Default Thread size for sender unit.
    what is the tread size for the oil pressure sending unit?
    1984 D-90 Tdi
    71 IIa 88 Perkins Prima Powered
    1995 D-90 SW Tdi #413
    No Gas burner Here............
    Randy
    Nov 2007
    16
    Default 3/16 straight thread, i think
    try a 3/16 straight thread flare fitting.
    I was in a rush and drilled mine out and put in a 1/8 NPT. worked...for now.
    Default guessing
    I would guess that its a 1/8" british pipe tapered thread.
    thats the same as 1/8 " american thread, but its one thread per inch difference (28tpi instead of 27tpi).
    You can usually get away with putting a 1/8" male american pipe into a female british pipe thread hole, but not the other way around.
    This is purely a guess!
    1968 Land Rover "Park Ranger" camper **SOLD**
    1967 109 **SOLD**
    NADA Dormobile #601 **SOLD**
    1965 IIA 88 2.5NA Diesel
    1963 Mercedes 300se
    1975 Volvo C303
    KJ6AQK
    Nov 2007
    16
    Default straight thread
    i'm certain it is a straight thread. i just dont know which thread designation. go to hardware store and get a 3/16 -45 deg flare fitting.
    let me know if it works....
    Quote Originally Posted by Tdi Guy
    I purchased a replacement Rover unit but it didn't tighten. I ended up getting an adapter from NAPA which was more tapered and tightened nicely. Not more leak.
