1987 LHD D90 2.5TD
Just arrived in VT from France and includes a US title. Amazing bulk head footwells and door bottems. Chassis is in excellent shape ands never been patch with only slight surface rust. Newly reconditioned to 0 mile spec 2.5TD engine. New Ashcroft gearbox and 1.2 transfer case(1 year warranty on those items), new exhaust, springs, shocks, brakes, and exmoore seats. Only way to demonstrate how nice if really is a test drive. Gearbox, engine, and tcase don't even have 100 miles since rebuild. Could use paint as final finish item (we have a local ago that could do it for $2500ish) Price is $19,500. Feel free to give me a call any time. 802-324-3370
The engine is a service exchange unit - which means that it's been completely reconditioned.
Here is a list of the work we do to these reconditioned engines:
Cylinder Head.
Chemically cleaned and pressure tested, all threads checked and rectified.
New core plugs.
New valve guides.
Recut valve veats.
New valves.
New valve eals.
New pre-combustion chamber hot spots.
New injector seats
Head resurfaced.
Block.
Chemically cleaned and pressure tested, all threads checked and rectified..
Rebored, honed and resurfaced.
New core plugs.
Crankshaft crack detected, checked for tolerance and polished or reground.
New teflon coated pistons.
New oil pump.
New camshaft.
New camshaft bearings fitted and honed.
Tappet assembly checked and replaced where necessary.
New big ends, main bearings and thrust washers.
New cylinder head bolts.
We also supply:
New water pump.
New temp and pressure sensors.
New thermostat.
New cambelt and tensioner.
New joints, oil seals, oil filter and gaskets.
http://s251.photobucket.com/user/ste...brary/French90
