Originally Posted by
tweaked
It would seem as though it's not getting fuel.
Sometimes what it seems is what it is! Have you checked the fuel bowl on your fuel pump? Is it clean? If not, the fuel lines may have some level of blockage (check the fuel tank pickup tube, fuel lines, etc). Maybe the carb's jets are clogged?
Other thoughts: When was the last time you changed or checked the points on your distributor? Also - do you you have a spare condenser you can try with your distributor?
1968 Series IIa
