Not My Day! Electrical Issue Help Request
It must be that my Land Rover does not want to leave home. I am getting ready for her to go to a new home and she is acting up like she wants to stay. The truck ran great! First the carb problem this morning. See earlier thread. Now the headlights flickered and then stopped completely when checking them. Fuses good. Next, I removed the dash panel to check the switch and changed out for another one just to eliminate that being a problem. Still didn't work and now the heater blower, running lights, blinkers, wipers, fuel and temp gauges do not work. I must have shorted something out.
Fuses still good. Truck starts up and runs. Choke light works, horn works, interior ceiling light works. I have reviewed the wiring diagram. I have a 68 Series IIA USA spec negative ground. Seems like it might be the voltage regulator in the engine bay and/or the voltage stabilizer mounted to interior side of firewall behind dash panel. Any thoughts. The voltage regulator looks just like my Lucas one from my Triumph TR4.
Thanks in advance,
Jim
Jim Henningsen
Ocala, FL
68 Series IIA 88
