Results 1 to 2 of 2
Thread: 1/8" bspt thread size
    Dec 2012
    CA
    12
    Question 1/8" bspt thread size
    1969 Series IIA 2.25 petrol marine blue Is the oil pressure switch and the oil pressure sender to gauge both
    1/8" BSPT thread size? I have an adapter for spin on oil filter, banjo fitting and an thread adapter for fitting both units on the oil filter adapter. I want to change to another oil pressure gauge that uses a different sender with a male 1/8" NPTF thread. So do I need an adapter from female NPTF to male BSPT 1/8" ???
    1969 Series IIA 88
    LHD SW 2.25 petrol
    fairey overdrive
    Feb 2007
    East Granby, CT
    1,884
    I believe they are BSPT into the housing, but I think the original line to the gauge has BSPP female threads on both ends. Hopefully someone who knows for sure will chime in.
    For adapters, check out:
    http://www.metricmcc.com
