Yesterday I discovered a significant oil leak which left a trail into my garage. Turning on the engine, I can see a small stream of oil coming out of the steel line right off the oil filter. This is the one that has a spiral steel shield around it, and goes into the instrument panel, and presumably the oil filter. I removed it, cleaned and reinstalled it with the hopes it was simply lose or something. No such luck.
My guess is this is not a repair item. The nut which attaches to the fitting is crimped on, and likely the inner hose has a crack. I'm not looking forward to this since taking the plate holding the oil pressure gauge takes at least one ounce of skin off my knuckles just to look behind it.
I was unable to find anything like this on the host's site, and also looked on another.
Does anyone know what this is called, and where I might find one, or a suitable replacement?
