Layshaft sheared in my IIa suffix B gearbox. Some of the broken bits are brass. Looks like it my be a shim of some kind. Can't figure out where they came from.
Double posted, sorry
Hi,
First impression is syncro unit... remove top cover and try and look inside. You are in for removal anyway. Had the same with an old gearbox where the layshaft bearing went and destroyed 3rd gear and syncro hub.
Please post findings.
Andre
1956 107 S1 SW 2.0 petrol - Matilda
1962 88 S11 2.25 Petrol - Buksie
1968 88 S11A 2.4 Diesel - Little Blue
1968 109 S11A 2.6 HT - Dusty
syncro looks ok!
bearing fail on end of layshaft. original brass cased bearing. Explains brass oeices
