Results 1 to 5 of 5
Thread: wiring (sigh) for series III 1972
    Default wiring (sigh) for series III 1972
    I'm on my 3rd mechanic (I live near cooperstown, ny about 1 hour west of Albany and Saratoga).
    Two wouldn't look at it; the 3rd has had it sitting outside now for nearly 6 months. Does anyone know of a mechanic who will work on wiring (replace main harness) in my area?
    Thanks, germaine
    Cooperstown NY
    304
    Hi Germaine. I live in Cooperstown also. I think we've met before. What are the problems you are having?
    Doug Gable
    Doug
    61 Series II 109 SW
    95 RR County LWB
    06 Range Rover
    98 Discovery LE
    Redding, CT
    1,504
    Try Red Barn Engineering in Saratoga Springs. Owner's name is Bob and he's a solid guy.
    (518)581-9119
    Dec 2014
    225
    I know this sounds crazy, but installing a wiring harness is pretty easy. It may seem daunting at first but think of it this way. Right in front of you, you have a life size example of how the harness fits in the truck. Take a bunch of pics before you start.
    When you start clip off the wires from the gauges and equipment leaving as long of a piece of wire as possible. Do not disconnect the wires at all. Leave the clipped wire as a huge hint for later. Once you have dismembered the harness remove it. Now install the new harness. For those wires with visible colors you can basically match up with the new harness, remove the old clipped wire and put on the new.
    There will be wires which have been replaced over the years, or ones you can't see the color coding any more. You'll need to refer to a wiring diagram at that point. Don't let the diagram stress you out. It is simply just like a road map. Find the instrument or device you need to connect on the map. See the color codes which need to be connected to that device on the map. Connect the wires.
    There is a system for the color coding. Terri-Ann has a fabulous website covering everything Series Rover. Here is a link to the color coding scheme: http://www.expeditionlandrover.info/Lucaswirecode.htm
    You can use this to figure out those few extra wires that don't seem to have a home.
    Give it a shot!
    --David
    1959 TR3
    1970 Series IIa 88" ("Homer")
    Sep 2010
    killingworth CT
    836
    Yeah, spend some time looking at the diagram for your truck, then label everything before cutting, it is pretty easy actually, use a simple tester to test for continuity, you should be set, cheers,
Tags for this Thread
