Results 1 to 5 of 5
Thread: Oil for bottle jack
    Apr 2010
    120
    Default Oil for bottle jack
    OK, in the category of "learning from your mistakes," I bought a used Coram bottle jack and turned the valve too far so some of the oil leaked out. Does anyone know how to refill it, what kind of oil to use, and how much? The pictograms that LR printed on the label are useless. - Thanks.
    1970 Series IIA
    1964 Series IIA [sold]
    Oct 2011
    Mountains of Western Pennsy.
    578
    There should be a plug about half way up the body of the jack, it might look like a rivet head, but it's a rubber plug. Some of the better jacks had an actual screw in filler. Fill it up with "Hyd. Jack Oil" or just use automatic transmission fluid. Fill only to the bottom of the filler hole, this is messy; lay it on it's side and fill with fluid, then stand upright and see if it's up to the bottom of the filler hole. Done...
    '99 Disco II
    '95 R.R.C. Lwb (Gone...)
    '76 Series III Hybrid 109
    '70 Rover 3500S
    Apr 2010
    120
    Thanks, I just tried it and now it works perfectly (and yes, very messy)
    1970 Series IIA
    Oct 2011
    578
    Great! Now, you're set for life on this job, as most every bottle jack made is similar.
    '99 Disco II
    '70 Rover 3500S
    I also faced the issue it really gets messy to bear out these types of things. I have been living in the woodbridge and its quite hectic that I can not find a good mechanic who can do it for me.
