Handheld tachometer - recommendations?
Collapse
X
  • Time
  • Show
Clear All
new posts
  • IIA
    1st Gear
    • Apr 2010
    • 160
    I'm looking for an inexpensive handheld tachometer to tune up my Series truck. I've never used one and most of the ones I see on Amazon only mention small engines. Can anyone recommend one that'll work on a truck --- and how do you use it?
    1970 Series IIA
    1964 Series IIA [sold]
  • jimrr
    4th Gear
    • Dec 2010
    • 472
    #2
    tach/dwell meter probably find on e bay, hook to #1 plug wire but I generally go by sound. there is a app for your phone that's pretty accurate.
    • Winstonsalemseries3
      Low Range
      • Feb 2021
      • 7
      #3
      I've used an Innova 5598 timing light in the past on various engines, but they are not exactly cheap (~$110). I think it is probably worth the money if you are going to mess with engines though. You can use it to time an engine, measure tack, and measure dwell. One wire to hot, one to wire to ground, one wire around the #1 spark plug lead, and a fourth wire for dwell. They have good directions.
      • vlad_d
        2nd Gear
        • Apr 2021
        • 244
        #4
        Back in the day, I just got one at AutoZone/O'Reilly's for like $30. I think it was a Sunbeam. If I remember right, it had a clip around the #1 spark plug wire and a smaller clip off the distributor (probably +12v power). It was about 6 inches wide and 4 inche tall... a little box. Handy to set down on the firewall or fender, but watch the fan and wires if you put it on the radiator(where it's most comfortable). I might get another, now that you mention it. It was great for carb tuning.
        ...|______OD__|__\\_____
        1973 Series 3, 109
        Working...
