Results 1 to 5 of 5
Thread: Coolant Confusion! Which coolant for a Series II 109
    Default Coolant Confusion! Which coolant for a Series II 109
    Hello! I have a1960 Land Rover Series II 109 (diesel) and I'm locked in an infinite loop of confusion while trying to determine the proper coolant to fill the radiator with. The confusion is borne of two competing ideas: The first: "Definitely use the green colored ethylene Glycol based coolant for your Series II Land Rover!" The second: "Check the color inside the cap and definitely use whatever the last guy used!" So, I have a 1960 Land Rover Series II (that suggests I should use the green ethylene glycol) AND the last guy used orange (which, suggests I should use the orange XLC). Any assistance here would be appreciated. Thanks.
    Oct 2007
    Gig Harbor,Wa
    36
    I've always used the green antifreeze in my older rigs.
    Erik Peterson
    Gig Harbor, Washington
    Oct 2011
    Mountains of Western Pennsy.
    592
    Flush out the whole system and put in Green. I wouldn't use orange (Dexcool) in anything, it's crap...
    Sep 2010
    killingworth CT
    836
    Greetings, Depending upon how long the previous 'Batch" was in the system you might consider the Prestone flush, it works great, just mix with water, let circulate, drain and repeat, then add your 50 to 50% mixture, it makes sense to use DI (De Ionized) water, you can buy it at a pharmacy, cheers,
    Thank you cedryck and thanks to everyone for your responses. Solved in record time. This forum is Awesome!
Tags for this Thread
