Results 1 to 2 of 2
Thread: Water Ingress Driver Side Roof Area
    Default Water Ingress Driver Side Roof Area
    Hi All ,
    got an issue with my 2003 D2 , I have noticed water sitting in the inside of the roof after it has rained.
    Can’t seem to pin point the area.
    Have tried to attach a few images below but can see how to , can someone advise
    The roof lining was removed as sunroofs were sealed shut , roof rails were also resealed & windscreen also replaced.
    Can’t be the windscreen as the water would have to travel up to that area to be leaking from there.
    See images below .
    The pic from the outside is roughly where it is coming in from on the inside.
    Also the water droplets on the door frame is just the water trickling down from where the water is sitting .
    Cheers ,
    RizzleKicks
    See images attached that relate to previous post.
ID:	13786Click image for larger version.
ID:	13787Click image for larger version.
ID:	13783   Click image for larger version.
