All of a sudden my driver and passenger mirrors tilt upward when in reverse. What could be causing this? Can I shut them off?
this is a common problem that happens when you do any work in the vehicle and unplug the battery or the wrong fuse.
set the key to position II and then set mirror to the desired viewing and then press the set memory + 1 or 2 in the seat control that should solve the problem.
you may have to do this set up individualy for left and then to right side ( make sure to keep the switch on for the side you are working with)
