Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Clutch not disengaging - bled but struggling with settings
  1. #11
    Jun 2008
    Southern California
    86
    Quote Originally Posted by jimrr View Post
    my condolences but when stuff gets tight it's better to adjust schedults, kick back and really dig in ........... there IS A REASON, . as a professional engineer that often had to diagnose various systems (power, electrical, ac, water .......... )) i learned you can not accurately diagnose without understanding how it works. I know I know ........ I had to study book after book and it would eventually pay off, no one else figured it out, i would but it may take 2 days of intense scrutiny !!!
    Good luck and don't let up !
    This is from another forum, and a post from another user, but perhaps it's of use for you or someone in the future:
    "The green Bible gives two methods to adjusting the slave pushrod. The 2 7/8 approach OR you can adjust the push rod so that (when the clutch is fully depressed) there is approximately 1/8 in (3mm) of clearance between the bottom of the piston and the circlip at the bottom of the cylinder.
    The latter is a better way in my opinion - with different length push rods, clutch plate thicknesses, etc. It gives you a good starting point for the (remaining) life of the clutch plate and ensures the slave cylinder's piston never bottoms out at either end.
    The volume of fluid (travel range) moved in the slave cylinder is determined by the master cylinder. All the push rod does is determine where, in the slave cylinder, that fixed travel range takes place. Ideally the bottom of the slave cylinder's piston (when clutch is fully depressed) is as close as possible to the bottom of the slave cylinder without bottoming out. As the clutch plate wears, the bottom of the slave's piston will get a little higher relative to the circlip."
  2. #12
    Jul 2020
    UK
    303
    A long shot but do you have a 9.5" Diaphragm spring clutch or a 9" coil spung one? I had your symptoms when my Diaphagm Spring mounting in the cover started breaking up, very difficult to see, but it meant when operating the pedal, although it reduced the pressure on the friction plate it didn't totally remove it. This meant on the move it was sufficient, but stationary it dragged too much.
  3. #13
    Nov 2021
    Niagara
    37
    It could be that the pivot on your clutch fork has worn excessively. Some are plastic and very weak. You would have to look inside through a port or pull the transmission.
  4. #14
    Dec 2010
    400
    i didn't read thru all this (again) but is the pedal firm? sometimes it's notoriously hard to get the air out. with hydrostatic the pedal will be firm from the top down, a most steady force to be applied, no soft then firm feelings. ?
  5. #15
    Dec 2010
    400
    i ran my clutch master cylinder low the other day. I filled it but what air in there is slow to work its way out but since it still works ok i'm not crawling in the snow and mud to deal with it occurs to me that if the pipe to the slave has ANY high spot in it, a air bubble in there may not be easy to flush out. the next time i'm under there i'll insure the pipe hasn't been altered (hit by tree limb etc) I also thought woring the clutch while on a steep hill (both directions) could help dislodge air. this may be worth a effort?
