Results 1 to 4 of 4
Thread: Rivet advice for window lock
    Apr 2010
    148
    Default Rivet advice for window lock
    I'm replacing a window lock https://www.roversnorth.com/parts/pl..._iia_door_tops this weekend. Any advice on what the right rivet to use is?
    1970 Series IIA
    1964 Series IIA [sold]
    Jul 2020
    UK
    302
    The Rover part is 78248 which is a sealed POP rivet 3/16" dia x 0.45" long . It is listed with our hosts
    Apr 2021
    SF Bay Area
    234
    Definitely use the LR part number, if you can.
    In my case, my door was a little “used”…so I ended up having to enlarge the hole. Also happens as the window lock is flimsy plastic that easily warps as you’re trying to drill out an old rivet. So, I ended up going to the hardware store for some aluminum rivets of the next size. Aluminum so they won’t rust with the morning dew or condensation(temp differential from inside to outside window makes water). Not 100% matching…but beats paying $25 shipping on some $3 rivets.
    ...|______OD__|__\\_____
    1973 Series 3, 109
    Jul 2020
    UK
    302
    Sealed Rivet for Metal lock on 2A door window . Picture below
