Front differential pinion bearing replacement
I have a vibration coming from the front differential pinion while driving since I’ve owned my 1969 88 (16 years). Just rebuilt the engine and transmission and started driving after many years of sitting in the garage. I ended up removing the front driveshaft after I realized the problem, which stopped the vibration but I have no 4WD. I Bought a rebuild kit recently to replace what I believe is the issue (pinion bearing). So, I have a potentially stupid Question: do I need to fully remove the differential from the axle housing to replace the bearing or can this be done installed in the vehicle?
Erik Peterson
Gig Harbor, Washington
'69 SWB Soft Top 2.25 petrol LHD
'71 LWB 2 Door 2.25 petrol LHD
"Every trip is an adventure in a Land Rover".
