Results 1 to 6 of 6
Thread: low fuel pressure
    Default low fuel pressure
    My SIIA 2.25 petrol occasionally stalls from what I believe to be fuel starvation. I have replaced the fuel pump, carburetor, fuel filter and now I will put in a new fuel line from the fuel pump to the carburetor. However, I noticed that the clear fuel filter is not filling very fast at all. Just a trickle. I have had fuel starvation issues for months. What should I do next? Is there a way to measure the correct fuel flow?
    If u call i can walk u thru a few tests for this issue. 360.866.2254 days
    North MS
    980
    Unfortunately, most of the aftermarket mechanical fuel pumps are junk. I have ended up replacing them on every Rover with a simple electric pump. However, the pump cannot be mounted in the engine bay, as it will get too hot (particularly in the summer) and can cause vapor lock (bucking).
    Something else to check, if you have your original fuel tank, is for rust in the lines and a clogged pick up tube in the tank itself.
    67 IIA 109" NADA Wagon (sold)
    Dec 2010
    399
    undoubtedly restricted fuel flow at/in the tank. back blow it with a air hose and see if you get a good flow at least for a few moments.
    To everyone who responded to my vexing problem of "bucking" and surging; THANK YOU. The entire issue was indeed caused by fuel starvation, so upon pulling the draw tube from the tank it was discovered to be "home made" and partially clogged with hair, or fibers of sorts. I installed a new draw tube and the problem has vanished. I took it out and thrashed it hard today and it performed flawlessly.
    Sep 2010
    killingworth CT
    836
    Quote Originally Posted by Nigel70 View Post
    Good, check that periodically, and if you have a weber carb, there is a little filter accessed by a brass bolt that often gains sediment, especially if you are in dirt or sand with your truck.
