Originally Posted by
luckyjoe
Here is installation info from my post on the old BBS:
OK, here is the additional info I have on the dual gauge components. The gauge displays Oil Presssure and Water Temperature. For Oil Pressure, a flexible steel oil pipe runs from the back of the gauge to the oil filter housing. The oil pipe has a swivel compression nut at each end, one attaches to the gauge, the other to a banjo fitting at the filter housing. These are the part numbers for the oil pipe, banjo fitting and adaptor at the filter housing:
279785 Oil gauge connecting pipe
502655 Banjo for oil pipe
502653 Adaptor for oil pipe
232039 Joint washer for oil pipe and switch (2 req. for banjo, 1 req. to refit oil pres. switch)
>snip
