Results 1 to 7 of 7
Thread: Need a good source for sound damping material for the roof of my Defender anyone know
    Feb 2007
    CT Coast, Stowe, Palm Beach, Nantucket
    321
    Default Need a good source for sound damping material for the roof of my Defender anyone know
    where I can find a good product? I have been trying to find closed cell foam sheets but have had no luck and I don't want to use that "mouse food" stuff that Land Rover used. I'd use dynamat but that would cost a huge $$$ to do the whole thing.
    Any thoughts?
    Thanks!
    May 2007
    Bloomfield, CT
    1,382
    I don't know what the material is called, but when a friend was building his new house, the plumbing contractor put down a closed cell plastic sheet underneath the radiant heating tubing before they poured the concrete floor of the basement and garage. The material was about 3/8" thick, came in a roll about 8' wide, and one side was aluminized. It had a honeycomb construction. It was used to prevent the radiated heat going downward. If it can act as a heat insulator, it would also, likely, work well as a sound insulator. Eitherway, both would be nice additions in a drafty, noisy Defender. It would be so easy to cut sheets and glue them to the underside of the headliner, inside the doors, etc.
    Jan 2007
    Boulder, CO
    13
    Try this.... http://www.b-quiet.com/
    They have all types of sizes, even stuff for under the bonnet!!
    Sep 2007
    Beaufort, SC
    22
    Try McMaster Carr, http://www.mcmaster.com/, product search for "3394" and you will find everything you need. The best is the Acoustical Foam/Lead Absorber-Barriers, but it is really really pricey, but the standard skinned or foil faced ones ought to get the job done nicely.
    CT
    290
    I used foil-faced foam from Homo-Depot (normally used under vinyl siding on your house); about 1/4 inch thick on the roof, and 1 inch thick on the roof sides. Excellent thermal as well as noise insulation, but a soft interior surface will absorb more sound than what is behind it. I have a 3/4 inch rubber mat on the floor and on top of the wheel wells in the rear of the 110. This also deadens a lot of noise from below.
    For road noise, usually the tires are the culprit, and not a whole lot can be done about it (except getting less aggressive tread).
    Under hood insulation is great for engine noise (particularly a diesel) but also the new one-piece foot well inserts are better than the older ones by far. I also run thick rubber mats under the factory (thin) rubber mats on the floor in front.
    Also, the rubber cover for the metal rocker cover on the 300Tdi deadens a lot of racket from the engine... This might fit a NA diesel as well as a 200Tdi as wel- I've never tried it, but it may work.
    Photographer / writer for LRM (until they screwed me).
    1995 110 Regular
    300Tdi, Series and Defender repairs in CT
    Quote Originally Posted by J!m
    Any idea where I can get one? I have a 2.8 TGV diesel in my 110, and am looking to quiet the diesel noise.
    CT
    290
    I'm sure Les from RN can find one for you...
    1995 110 Regular
