Greetings from a 95 Classic SWB newbie
Greetings from N.C.,
1. Looking for recommendations for an aftermarket front bumper that will support a winch on a 95 SWB - still has the air suspension. SRS compatibility is preferred, but not essential.
2. Hood latches in the middle ok but there is significant play on each end. At 65mph, the hood shakes badly.
3. Remote entry inoperable - things to check?
4. Cruise control inoperable - things to check?
5. Radio display light burned out - easy to replace?
Lastly, need tyres - anyone know what is the max recommended size for stock (air suspension) Classic?
Thanks in advance.
well i dont have answers to all your questions but the ones i have fixed on mine are the following:
1) my remote just needed new batteries and then the system needed to be reset, there is a procedure but i dont remeber it, hope someone can post it
2) my cruise didnt work becuase it had a crack in the bellows and in one of the hoses, under the hood on the drivers side you can find an small black bellows right by the brake fluid resivouir. check it for cracks and check the tubes too. also check the cruise fuse
