LT-230T disassembly question
I pulled off the rear "pto" cover on an LT230 from an '88 RR. Underneath that I found something called an "oil feed plate".
How do you get this thing off? Off course the manual simply says remove it. Just like it simply says to remove the cross member when you want to change the transmission filter.
I figured I'd better ask before I start prying and break something.
Thanks,
Dan
