Originally Posted by
Terrys
I ignore the voltage readings simply because they are what they are. If I suspect a TPS, connect the multimeter, in a low ohms scale to the TPS. I can't remember which colours are the terminal ends of the resistor and which is the wiper, but what you're looking for is a smooth needle deflection from low to high (or high to low if you're connected to the wiper and the high end) without any jumps or drops in the needle.
Digital VOMs are not neaqrly so usefull as a good old simpson 260 analog meter.
If you really must know the colours, I'll grab one from the junk box tomorrow and give them to you. There is only so much crap I can remember these days, and the TPS colours isn't one of them.
