CA Range Rover Classic 100 inch frame
1989 Calfornia rust free Range Rover chassis. Perfect for donor for Series coil spring swap/Range Rover restoration. Only $50! Buyer collects from Paso Robles. Also, good serviceable viscous coupling unit that fits 1989 to 2001. Slight inner spline wear as seen in images, but completely usable. Was removed when LT230 swap was perfomed. Can be installed without removing entire transfer case from vehicle in 45 minutes. Yours for $100 + shipping. Compare at remanufactured cost of $800. Images can be sent to interested parties
