Originally Posted by
JLT77
My cooling light keeps coming on because I am loosing fluid somewhere. When I open the holding tank the water level is low. Here is what I know.
I have inspected all the hoses for leaks and everything is clean and dry.
The motor runs very good so I do not think I am leaking fluid into the motor.
When I inspect the oil level on the dip stick the oil is not all foamy looking so I don't think there is water in my oil.
I used to be able to top the tank off and have it last for a week before I had to do it again. Now I get about a day out of it.
Does anyone have any trouble shooting ideas?
I am thinking the cap is not sealing right but it holds pressure.
Could a small pin hole in radiator leak fluid slow enough that it evaporates leaving no trace behind?
Thanks everyone.
Jeff Thomas
92 RR County
Check the interior RHS footwell for dampness. You may have a leak at the heater matrix either from a bad connection or a bad matrix. Although you should be able to smell it when the vehicle comes up to temp.
Also check the valley pan gasket located under the plenum. I've heard other cases and experienced this first hand on an '89 RRC. It was burning off until one day the gasket took a crap. I was able to limp home and order a head gasket kit with new composites and stretch bolts from RN. Took the weekend to finish. I re-lapped the valves while the heads were off for good measure.
1996 D1, 4.0L, AUTO "Lucas"
