95 RRC 4.2 asking for help w/ diagnoseing an engine problem
Hi
I have a 1995 LWB RRC, new problem started this week on a rainy day (dont know if that matters)
the engine started running really rough at a stoplight (almost stalling) and then when i tried to accelerate it had very very little power and made a couple of coughing / popping sounds. I pulled into a parking lot and it was at a really low rpm idle, almost stalling. Then the check engine light came on (45 - O2 sensor) and it ran smooth again.
I went to drive home and again really rough, low rpm idle and with no power on accelartion or even the slightest hill.
I know it could be many things, and not just the o2 sensor, but i dont have any idea how to diagnose the problem.
Any help would be great.
Thanks
check your catylitic convertors, the inner meterial deteriorates and turns to powder and plugs the screens,the easiest way to check is to remove the front o2 sensors and see if it regains the power.....
Had the same problem with mine. Had a crack in the flange above the cat. Check the manifold for cracks. I replaced the Y pipe and O2 sensors and it ran fine for a while again. Had some other issues with the left bank fuel rail and poor spark. Do these symptoms sound familiar? If all else fails you can always use a can full of gas and a hand full of matches to fix it.
Unplug the O2 sensors as was mentioned before and if they are the broblem the engine should run fine but with a slightly richer mix!
ok so thanks for the advice
not sure if i was supposed to pull the o2 sensors or just unplug them
but i unscrewed the left one from the exhaust pipe and unplugged it from the wire so it is completely out.
The top 1/2 of the sensor is white, the bottom 1/2 is black and a bit greasy. I have no idea how they are supposed to look. Please let me know, and thanks again everyone.
You can just unplug each one from there own female/male conectors so that when the computer senses them not there it will go into default mode. You moght want to put that one back in or it will get pretty noisy when you start it up. o2 sensors are very complicated pieces of engineering, your lucky you got a code! oh and they can just go when ever they feel like it too!
- You may not post replies
- You may not edit your posts
Forum Rules
