interior clock removal
On a 1995 Discovery - I cannot seem to locate any
pin to depress or lever to push up on while I remove this clock
the bulb I out and I hate using a flashlight to see what time it is
at night. anyone remove the clock before - any tips on how and if
its liable to brake apart in my hands (as it feels it would if i pull hard)
-cheers
Hey there,
There is a diagram you can use that shows you how at atlanticbritish.com. Look under the tech tips section. There are 4 tabs that you need to lift at the same time. I just used a credit card and cut it into 1 cm strips. Hope that helps
Dave
