I have a 03 Discovery II and every time it takes a shower (due to raining conditions or washing it) water pours from the back door. Any clue how to fix this issue. All rubber protections are in place and in good conditions.
I've got the same problem! My late 02 disco only shows this when i give him a good shower. With rain there's nothing wrong!
I Pasted your question (because of the better english ) here: http://www.discoweb.org/forums/showthread.php?t=44999 And got a very good answer!
I have an 01 disco and had the same exact problem. Look careful at the rear door seal... peal it back (no need to pull it out) in the area(s) when you think it is leaking water. In my case i found a tiny hole and sealed it with clear water proof silicon and no more water!!
hope this helps!
Originally Posted by san988
Thank you, JEDEGO. I'll try.
