My ignition coil pack is arcing - is there any hope of repairing it, or must I shell out $600+ to replace it?
Thanks,
jv
Thanks,
jv
They are not repairable, however I would eliminate the possibility that it might be a bad plug wire by at least making sure they are securely fastened at both ends, if not replacing the wire set first.
Are you getting a SES light? We would read this with Autologic and depending on which cylinders are misfiring (IE if they share a coil) then we would replace a coil pack.
Adam Check
JE Robison Service
Technical questions answered via e-mail and AIM!
E-mail address/AIM screen name: Adam@RobisonService.com
If You have a few days to wait for parts You can contact Rimmer Bros in the UK. Order p/n ERR6269P. cost is $360.71 plus shipping
Http/www.Rimmerbros.co.uk
check your plug wires 1st.......bet thats the problem...
