what is the expected turning radius of an 88" rover. Mine seems pretty wide, wider than any other 4wd's I've owned. When I first set my wheel stops I was conservative and couldn't believe how bad the turning radius was. I jacked up the front end, turned in the stop bolts, turned the wheel all the way to one side, adjusted the stop bolt to touch the tab, backed off the wheel and then turned the bolt one turn. Repeated on the other side. Going back, the first thing I did was find the center of the steering box and adjusted the drop arm to straight down and the other arms per the manual. Is this just what I get or do I need to do some further adjustments, can't think of any.
Bob
