Is it an original Rover solenoid? I usually just use an old *eep solenoid or AMC solenoid. Common as dirt and fairly reliable.
On the Rover solenoid you will have two main studs. Obviously one goes to the battery and the other to the starter (usually it makes no difference which is which). On the battery side you will have two lugs that go over the stud itself. The large one hooks up to the alternator as a charge return. The smaller one is simply a continuous hot lead, usually hooked up to something like a horn or spot light. Then there should be one wire connection lug somewhere on the solenoid body that will hook up to the ignition. This is what "clicks" the solenoid to start the vehicle.
One final note: There are two types of solenoids. Internally grounded and externally grounded. Internally grounded solenoids will have two external lugs on the body, one goes to ground, the other to the ignition. Externally grounded solenoids must be well secured to a good ground source as they have only one lug that connects to the ignition. All of the Rover solenoids that I have dealt with have been externally grounded.
Hope that answers the question.
67 IIA 109" NADA Wagon (sold)
