I just started having a similar issue. Here is what I have...
I had the ignition switch fail...
I ordered a new one from RN, it takes a week or so to arrive, in that time, the battery dies.
I change the ignition switch over, charge the battery and it works great.
Now, over night, the battery dies and when cold / cool the truck idles fine, but when fully warm, it will idle for about a minute, then start to die, recover, stumble, recover ( or die ), then stumble and die...
Weirdness, I did not have any problems with the idle OR the battery before the ignition switch went bad, while the ignition switch was failing ( a little jiggle behind the dash would start it ) there were no problems...
Oh I got a nail in a tire during all of this, but I am pretty sure that is not related :-)
I also have a leaking Clutch Master Cylinder, I already have the parts and a shop manual, but I was wondering if anyone had any tips / tricks to make the job easier?
Thanks in advance,
Alan
