Originally Posted by
Aztec Rover
To pull the steering wheel just fold down the tabs on the locking plate and then loosen the nut so that its flush with the top of the threads on the steering column. Sit in the seat with your knees pushing up against the steering wheel, pull the top of the wheel up with your hand and using a plastic mallet give the nut a sharp blow. The steering wheel should come loose without the need for a puller. Remember don't overdo it with the mallet and with the nut being flush with the threaded steering column it should prevent damage to the threads.
I have been removing steering wheels in this way for over 20 years with no damage.
pull the steering wheel for a broken speedo cable? Am I missing something?
Incidentally I found an easier way to pull my steering wheel when I first got my truck - it came off in my hands when I pulled myself into the truck one day. Guess the PO forgot to tighten that nut enough....
'67 sort of station wagon (limestone), '65 gray hardtop, '63 blue Station Wagon, '64 limestone station wagon in pieces
