Is it a Webber? Sometimes the ports get clogged with dirt, and you need to clear them. What's nice is, it's really easy!
- rev the crap out of the engine with the goose neck off the carb
- place your hand over the carb top when the engine is at top RPM and wait for the RPMs to die almost to a stall (but don't let it stall)
- remove hand and keep it running with other hand on throttle
- check idle...
- repeat if needed.
When you are done, you may need to re-adjust the idle and idle mix (per carb. instructions) depending on how long it has been since you last adjusted it. If several 'cleanings' does not straighten it out, adjust the idle set and mix. If it still idles like crap, it may have to be rebuilt...
I have to do this occasionally in my series, and this trick always fixes it up.
I'm not sure if it will work with other carburettors...
1995 110 Regular
