hi all! new to this forum, and already askin for help. my '96 disco has sprouted leaks at either end of the intake valley gasket. is there supposed to be a gasket underneath the spreader bars on the ends of the valley gasket, or do the spreader bars sit right on top of the black valley pan gasket? one exploded view i have seen shows a gasket, and another makes no mention of one, i would like to fix this the right way before i lock-tite the bolt that holds the spreader bar down on either end, as they have come loose before. i changed the coil pack recently and found the leak at the rear of the intake to be pretty bad, and i would like to know if anyone else has had this problem and what action should i take to repair this correctly. thanks in advance!
