Diesel INTAKE noise??
2 years ago, I changed the stock air filter assembly on my 2.5 NA diesel ($45 air filters) to a Toyota air filter assembly ($9 air filters). I used a rigid, thin-wall aviation air intake hose between the filter assembly and intake manifold instead of the too-short stock air intake hose.
I couldn't believe how LOUD the intake was with the new setup. I ended up wrapping the intake hose with foam-rubber pipe insulation, which quieted it down quite a bit.
Well, the other night I removed the intake hose and showed a friend how loud it was with the hose off. He said (and I agree) that it sounds a bit like an exhaust sound coming from the intake manifold.
Now I'm wondering if a rocker/valve clearance issue might be causing exhaust noise in the intake manifold. That would be nice, as it's a relatively easy fix. Also, I've never changed the timing belt on this engine (no timing specialty tools). This engine was one of Les' Loft items 4 years ago, so I don't know how many miles are on it.
Anyone ever experienced something like this on a diesel? Are diesels normally noisy intake-wise?
--Mark
